Выпал в kernel panic
Cramac
Сообщение Cramac » Сб авг 05, 2023 6:44 am
Всем привет. Сегодня сервер решил потухнуть вот с такой ошибкой:
Aug  5 06:21:14 hosters kernel: [6296043.887031] ------------[ cut here ]------------
Aug  5 06:21:14 hosters kernel: [6296043.887035] kernel BUG at mm/vmalloc.c:477!
Aug  5 06:21:14 hosters kernel: [6296043.887038] invalid opcode: 0000 [#2] SMP NOPTI
Aug  5 06:21:14 hosters kernel: [6296043.887039] CPU: 2 PID: 3836455 Comm: sshd Tainted: G      D           5.4.0-149-generic #166-Ubuntu
Aug  5 06:21:14 hosters kernel: [6296043.887040] Hardware name: Micro-Star International Co., Ltd. MS-7D46/PRO H610M-G DDR4 (MS-7D46), BIOS 1.70 06/24/2022
Aug  5 06:21:14 hosters kernel: [6296043.887044] RIP: 0010:__purge_vmap_area_lazy+0xd4/0x6d0
Aug  5 06:21:14 hosters kernel: [6296043.887046] Code: 05 a1 f6 e4 01 49 89 f7 4d 89 ee 49 29 ff 49 c1 ef 0c 48 85 c0 0f 84 90 04 00 00 48 8b 50 f0 48 3b 78 f8 73 07 48 39 d6 76 19 <0f> 0b 48 39 d6 76 f9 48 8b 48 08 48 8d 50 08 48 85 c9 74 12 48 8b
Aug  5 06:21:14 hosters kernel: [6296043.887047] RSP: 0018:ffffc09cc3343b88 EFLAGS: 00010287
Aug  5 06:21:14 hosters kernel: [6296043.887048] RAX: ffff9ffb0a441210 RBX: ffff9ffb61827840 RCX: ffff9ffb0a441210
Aug  5 06:21:14 hosters kernel: [6296043.887049] RDX: ffffc0dcc1365000 RSI: ffffc09cc1375000 RDI: ffffc09cc1370000
Aug  5 06:21:14 hosters kernel: [6296043.887050] RBP: ffffc09cc3343bc0 R08: 0000000000000000 R09: ffffffffb506de00
Aug  5 06:21:14 hosters kernel: [6296043.887051] R10: ffff9ffa86c4c280 R11: 0000000000000001 R12: ffff9ffa86c4c290
Aug  5 06:21:14 hosters kernel: [6296043.887051] R13: ffff9ff718fb7cc0 R14: ffff9ff718fb7cc0 R15: 0000000000000005
Aug  5 06:21:14 hosters kernel: [6296043.887052] FS:  00007f3b998d4f40(0000) GS:ffff9ffb6f280000(0000) knlGS:0000000000000000
Aug  5 06:21:14 hosters kernel: [6296043.887053] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug  5 06:21:14 hosters kernel: [6296043.887054] CR2: 00007f3b99cd2d30 CR3: 000000045b512004 CR4: 0000000000760ee0
Aug  5 06:21:14 hosters kernel: [6296043.887055] PKRU: 55555554
Aug  5 06:21:14 hosters kernel: [6296043.887056] Call Trace:
Aug  5 06:21:14 hosters kernel: [6296043.887058]  _vm_unmap_aliases+0xf5/0x130
Aug  5 06:21:14 hosters kernel: [6296043.887059]  vm_unmap_aliases+0x19/0x20
Aug  5 06:21:14 hosters kernel: [6296043.887061]  change_page_attr_set_clr+0xcf/0x200
Aug  5 06:21:14 hosters kernel: [6296043.887063]  set_memory_ro+0x29/0x30
Aug  5 06:21:14 hosters kernel: [6296043.887065]  bpf_int_jit_compile+0x2d1/0x340
Aug  5 06:21:14 hosters kernel: [6296043.887067]  bpf_prog_select_runtime+0xa7/0x130
Aug  5 06:21:14 hosters kernel: [6296043.887069]  bpf_prepare_filter+0x44c/0x4b0
Aug  5 06:21:14 hosters kernel: [6296043.887071]  ? hardlockup_detector_perf_cleanup+0xa0/0xa0
Aug  5 06:21:14 hosters kernel: [6296043.887072]  bpf_prog_create_from_user+0xc7/0x120
Aug  5 06:21:14 hosters kernel: [6296043.887073]  seccomp_set_mode_filter+0x11c/0x7b0
Aug  5 06:21:14 hosters kernel: [6296043.887074]  do_seccomp+0x39/0x200
Aug  5 06:21:14 hosters kernel: [6296043.887075]  prctl_set_seccomp+0x2c/0x40
Aug  5 06:21:14 hosters kernel: [6296043.887076]  __x64_sys_prctl+0x3ea/0x5c0
Aug  5 06:21:14 hosters kernel: [6296043.887078]  do_syscall_64+0x57/0x190
Aug  5 06:21:14 hosters kernel: [6296043.887080]  entry_SYSCALL_64_after_hwframe+0x5c/0xc1
Aug  5 06:21:14 hosters kernel: [6296043.887081] RIP: 0033:0x7f3b99cd2d3e
Aug  5 06:21:14 hosters kernel: [6296043.887082] Code: 48 8b 0d 55 c1 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 9d 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 22 c1 0c 00 f7 d8 64 89 01 48
Aug  5 06:21:14 hosters kernel: [6296043.887083] RSP: 002b:00007fffbdb79868 EFLAGS: 00000246 ORIG_RAX: 000000000000009d
Aug  5 06:21:14 hosters kernel: [6296043.887084] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f3b99cd2d3e
Aug  5 06:21:14 hosters kernel: [6296043.887085] RDX: 00005617d8899e60 RSI: 0000000000000002 RDI: 0000000000000016
Aug  5 06:21:14 hosters kernel: [6296043.887086] RBP: 00007fffbdb79870 R08: 0000000000000000 R09: 00007fffbdb78fcb
Aug  5 06:21:14 hosters kernel: [6296043.887087] R10: 00007f3b99cd2d3e R11: 0000000000000246 R12: 00005617d89fe500
Aug  5 06:21:14 hosters kernel: [6296043.887087] R13: 00005617d89f7d30 R14: 00007fffbdb79920 R15: 00005617d88510c3
Aug  5 06:21:14 hosters kernel: [6296043.887089] Modules linked in: ufs qnx4 hfsplus hfs minix ntfs msdos jfs xfs cpuid iptable_filter xt_tcpudp bpfilter nls_iso8859_1 dm_multipath scsi_dh_rdac scsi_dh_emc scsi_dh_alua snd_hda_codec_hdmi snd_hda_codec_realtek x86_pkg_temp_thermal snd_hda_codec_generic intel_powerclamp ledtrig_audio binfmt_misc coretemp kvm_intel snd_hda_intel snd_intel_dspcfg snd_hda_codec kvm snd_hda_core wmi_bmof snd_hwdep joydev snd_pcm snd_timer snd soundcore mac_hid acpi_pad acpi_tad quota_v2 quota_tree sch_fq_codel msr ramoops drm reed_solomon efi_pstore ip_tables x_tables autofs4 btrfs zstd_compress raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 multipath linear hid_generic usbhid hid crct10dif_pclmul crc32_pclmul ghash_clmulni_intel mxm_wmi nvme aesni_intel crypto_simd cryptd glue_helper r8169 ahci nvme_core libahci realtek video wmi
Aug  5 06:21:14 hosters kernel: [6296043.887111] ---[ end trace 841de3c802d483be ]---
в вложении полный лог
kern.zip
(8.69 КБ) 1253 скачивания
ahouse
Re: Выпал в kernel panic
Сообщение ahouse » Сб авг 05, 2023 6:53 am
Протестируйте оперативу
Обновите ось
Ubuntu 24.04
BCP: latest
Cramac
Сообщение Cramac » Сб авг 05, 2023 2:05 pm
до этого работал на centos проблем таких не наблюдалось. Ничего из железа не менялось. Но вот после перехода на убунту, пару раз уже выпало в панику...
ahouse
Сообщение ahouse » Сб авг 05, 2023 7:47 pm
Исходя из вот этого "kernel BUG at mm/vmalloc.c:477!" я предположил что могут быть какието слоджности с оперативкой. когда появляются кернелпаники это или железо или криво с осью чото.
я работаю с убунтами много лет - ниразу не довелось на них панику видеть.
Ubuntu 24.04
BCP: latest
Сообщение sbury » Сб авг 05, 2023 9:48 pm
Судя по логу или память глючная или перегрев самой ноды. Если вообще хаб не отвалился. Даже если бы были проблемы по винчестеру ядро бы не выпадало в панику с такими параметрами.
Cramac
Сообщение Cramac » Вс авг 06, 2023 2:06 pm
спасибо, проверю.
